hand throttle for a 100
Discussion in '100-Series Cruisers' started by Landpimp, Mar 5, 2004.
  1. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    is there such a thing? ya know every cruiser before has the provision for one.......but I dont see a place on the 100 for one, not that i really need it but ya know.........if they make one I would like it........all the rest got em :)
  2. e9999
    e9999 You want to do what...? Moderator
    16,629
    513
    Sep 21, 2003
    US
    use a cane? :D
    E
  3. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    I got a cane for you! :flipoff2:
    [quote author=e9999 link=board=2;threadid=12618;start=msg116147#msg116147 date=1078548653]
    use a cane? :D
    E
    [/quote]
  4. bjowett
    bjowett
    3,681
    1,383
    Oct 28, 2002
    Western Massachusetts
    The 100, despite having the throttle cable, has a motor driven throttle plate. If nothing exists, maybe you could come up with some sort of electronic control? I have a nice steering wheel with extra buttons that would work very well for ya. :flipoff2:
  5. Landpimp
    Landpimp GOLD Star
    15,932
    Media:
    1
    1,951
    Mar 14, 2003
    Gig Harbor WA
    true but like on a 60/62/80 the hand throttle cable attaches to the pedal, so there should be no reason to do anything different just cause the throttle itself is electic.
    its not something that I need....but was just curious.
    I have a vacumme hand throttle set up in my 82 fj40, even used OEM parts ;)
    John H
    [quote author=bjowett link=board=2;threadid=12618;start=msg116489#msg116489 date=1078623990]
    [/quote]
  6. spressomon
    spressomon glutton Moderator
    12,527
    Media:
    13
    Albums:
    1
    1,095
    Jan 9, 2005
    Northern Nevada
    Anyone rig a handthrottle up on a 100 yet (looking for the shortcut for this mod of course :D)
  7. 100 TD
    100 TD
    2,081
    16
    Mar 3, 2004
    OZ
    The 100 turbo diesel has an IDLE UP switch, the function of this switch is to rev the engine to about 1400 rpm when it is cold, to get it up to temperature quicker so that heating can be used inside the vehicle.(Similar to a hand throttle) It utilises control through the ECU and the electric throttle motor to do it though, which is unfortunate, as when it gets up to temperature the ECU says cut it out, no more high idle required. I am keen on info that would send a dummy signal to the ECU so it could be used all the time (ideal for winching keeping the engine at higher revs so the alternator is working hard and rechargeing the battery while you are ginning around between winch attempts etc). I am sure this function is also available on the V8 in colder climates, or possibly the middle east as I am sure I have seen a photo of one on a petrol cruiser somewhere. If this is the case the plug for a switch is probably sitting behind the dash in the US vehicles, whether this function is turned on in the ECU is another question! If it is and we could trick the ECU to be able to use it all the time it would be a bonus.
  8. spressomon
    12,527
    Media:
    13
    Albums:
    1
    1,095
    Jan 9, 2005
    Northern Nevada
    Couldn't find one for the 100 nor one I liked from another vehicle...so I ordered a Vernier Control from Aircraft Spruce; used some scrap steel I had laying around; a little bandsaw work and MIG and now I finally have my hand throttle on my '99!
    Dial in the perfect shower temp; rev up when winching and jumping other rigs :)
  9. NMuzj100
    NMuzj100
    3,480
    32
    Sep 25, 2004
    Gleneagle, CO
    The ECU in the V8 will automatically throttle up the engine on cold starts until it reaches operating temperature.
    The easiest point to modify electronically would be to modifiy the output of the Accelerator Pedal Position Sensor. FSM DI-104 has info someone a little more electrically inclined than myself could take advantage of.
    Where is the "Idle up" switch on the Diesels?
  10. 100 TD
    100 TD
    2,081
    16
    Mar 3, 2004
    OZ
    Above the electric mirror control.
