HALP! she wont start
Pacific NorthWest
looking for diagnosis help. i have a 84 HJ47 with her original 2h. she stopped running. cranks good and strong. i thought maybe a had an air leak and still do when i depress the manual primer fuel shoots up along the plunger making a mess and giving me a nice diesel manicure. additional she is now draining the battery while she sits verified nothing on and happened again. thank you for any thoughts
On mine, this needs to be pushed in for it to start, and pulled out for it to turn off. It was the same in a HJ45 I had. When I first got my BJ40, I had the same issue you had, but I forgot about that switch
Yup, primer pump will leak when the seal goes out. Once you pump it you bleed the air by the fuel filter. Repeat the process until all the air comes out. I purchased bosh one as spare. Sometimes people forget the water separator has to be drained. Good luck.
Wait where's the water separator
The other problem I have seen is diesel will develop fungus and will get into your fuel line and clog it. That is what happened to mine and I ended blowing out. This is not what expected but that it was when took a closer look.
Sounds like disconnecting the edic rod is the first thing to try?
Have you pulled a glow plug out to check they're OK?
Should still start without glow at a stretch but depends how worn out everything else is in your engine.
