Half way through my first birf job
Discussion in '60-Series Wagons' started by jts560, Feb 25, 2007.
  1. jts560
    jts560
    241
    Nov 14, 2005
    Winter Haven, Fl
    Well, after putting it off for a couple years I finally got around to rebuilding my knuckles. I'm a Florida boy but my truck is from the north, it seems like every damn nut and bolt is rusted. I've got everything dissassembled to the axle housing, just need to clean up all the parts and put it back together with new seals and bearings. It came apart without to much hassle, except the cone washers on the top of the knuckles on both sides. Funny how everyone says that the cone washers that hold the free wheel hub on are the toughest, not in my case. What a royal pain in the ass those were, luckily my neighbor is a heavy equipment mechanic, he came over and helped me beat, pry, beat, wedge, beat, jar and beat them loose, only broke one hand sledge. **** those things. He said that those were the most stubborn fasteners he has ever seen, and he has worked on everything from oil rigs to bulldozers. Looking forward to putting everything back together and getting the cruiser back on the road, with a liberal coating of anti-seize on the $@&*# cone washers.
  2. ranger
    ranger
    1,160
    6
    Jan 18, 2003
    Mountain Hole, Idaho
    I've had some that were a little stubborn, but usually a couple of wacks with a hammer, then tap a scribe in the slot on the cone washers to spread it out a little allows them to come right out.
  3. jts560
    jts560
    241
    Nov 14, 2005
    Winter Haven, Fl
    One more thing, my brake line bracket was riveted to the dust shield. I will definitely be drilling those out and replacing them with bolts.
    Oh, and the axle rebuild DVD makes it look WAAAY to easy.:D Did I mention that cone washers suck balls?
  4. jts560
    jts560
    241
    Nov 14, 2005
    Winter Haven, Fl
    These were really stuck on the studs, and when I say "stuck" I mean it in the strongest sense of the word.
  5. land crusher
    land crusher Morgen, morgen nur nicht heute...
    552
    Media:
    1
    Albums:
    1
    178
    Feb 14, 2006
    In the weeds
    My cone washers popped right off using the brass drift method. I must be lucky, cuz I've heard others with stories like yours.
    Anyhow, who puts out this DVD? Never heard of it.
  6. nicholastheczar
    nicholastheczar
    1,414
    6
    Aug 23, 2005
    Magnolia, TX
    I just finished my front axle rebuild and had pretty good luck. The bolt that holds the steering arm to the tie rod end needed a bunch of PB and a lot of attention.
  7. chicago
    chicago
    9,620
    Media:
    21
    Albums:
    1
    35
    Jan 18, 2006
    Reno, Nevada
    Hey bro!!
    I feel your pain with the cone washers on the top of the knuckle!
    It took me about 1.5 hours to get mine out on one side!
    I was trying to be all :princess: about it, finally, I got a small screw driver into the slot on the cone washer and was eventually able to work it free.
    They do suck ass!
    Chicago
  8. jts560
    jts560
    241
    Nov 14, 2005
    Winter Haven, Fl
    A guy in the 80's section put the DVD together, i'll see if i can dig the info up.
  9. jts560
    jts560
    241
    Nov 14, 2005
    Winter Haven, Fl
