had valve knock and a little smoke this weekend?
North Cadillac
It has never happened before. Left my truck sitting for 2 days at the body shop while we finished painting my hood and cowl. After we buttoned her all up, i went to back her out of the garage. When i started her up, there was some stumbling and ruff idle. Also, there was a very noticeable what i thought was valve knocking. I shut her off and checked the oil. It was registering at the bottom of the dipstick, but i figured that was normal since it was cold. So i started it back up and still had some valve noise. Then after a minute a little white smoke started coming out of the exhaust. After it had warmed up i checked the oil again and it was full, valve chatter had also gone.
I wonder what could have caused this? It's never happened before. It was as if the upper end was being starved of oil. I did check the oil pressure gauge and it was showing full oil pressure. I added a little marvel mystery oil and plan on changing the oil in a day or two considering it is about that time anyway. :meh:
Had the battery been disconnected? Could be a bunch of things, so before getting excited I'd check all fluids and basics and then just watch to see if it happens again. It won't be low oil - stumbling and rough idle will be something else and the white smoke may point to a leaking injector that causes a cylinder to misfire and belch unburned fuel.
DougM
When was the last time your intake hose was checked/replaced..?
battery hadn't been disconnected. It had just been sitting for a while. I did check all fluids and was a bit surprised that the oil was low. I realize it will show a little low when it's cold, but...
Intake was replaced about 1.5 years ago, new from Cdan. The old one was cracked in half. I did inspect and it looks fine.
Truck is running like a top right now. Really weird. I'll be honest, i thought i had popped a head gasket at first.
