had alittle problem at work
Discussion in 'Chit-Chat' started by 3_puppies, Aug 22, 2006.
  1. 3_puppies
    3_puppies SILVER Star
    9,916
    845
    Dec 2, 2002
    Helena MT
    shaft is supposed to be in one piece :D main shaft that the rotating assembly turns on. off a 300HP cone crusher
  2. -Spike-
    -Spike-
    6,693
    440
    May 26, 2005
    Phoenix
    :eek: You're gonna want to get out the thicker wire for the welder on that one.
    -Spike
  3. 3_puppies
    9,916
    845
    Dec 2, 2002
    Helena MT
  4. swank60
    swank60
    1,483
    231
    Aug 26, 2002
    One of Four Presidential Flying Saucers
    That should be pretty cheap to fix.
  5. Jman
    Jman
    1,548
    176
    Feb 20, 2003
    If ya don't know, I ain't tellin'
    BANG.
    Huh? [shrug]
  6. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,060
    530
    Dec 13, 2002
    Knee deep in hookers and gin
    I've crushed cones with my 200 hp Land Cruiser and it didn't break.
  7. Brentbba
    Brentbba Former Golfer SILVER Star
    10,129
    553
    Mar 27, 2003
    OC, CA
    Can you say OOPS boys and girls.
  8. 3_puppies
    9,916
    845
    Dec 2, 2002
    Helena MT
    probably be above $100,000 when all is done
  9. TX_TLC
    TX_TLC
    1,475
    8
    Apr 29, 2003
    Texas
    Did you run out of lub? :doh:
    "That is what she said" <- the perfect one liner to most any joke. :D
  10. Relix
    Relix
    785
    Media:
    18
    5
    Sep 19, 2005
    Fountain hills, AZ
    Danm that's some serious breakage!
  11. bundy18
    bundy18
    120
    Aug 3, 2006
    Lincoln, NE
    as long as it's not on your tab, ***t happens
  12. Skillet
    Skillet Skillet
    4,371
    Media:
    13
    Albums:
    3
    1,013
    Nov 10, 2005
    КАГІҒОЯИІА
    Hey!
    Can I use that piece to machine myself a new sector shaft?
    Bet I could not twist that one...:D
  13. White Shark
    White Shark
    763
    Media:
    1
    Albums:
    1
    2
    Dec 13, 2004
    Red Triangle
    I'll fix it for half that, but I can't warranty remanufactured parts.... ;)
  14. archie
    archie
    1,203
    4
    Dec 14, 2002
    NW side of chicago
  15. 3_puppies
    9,916
    845
    Dec 2, 2002
    Helena MT
    stuff does happen, boss was decent about it, not much we can do now but fix it. actually first major breakdown in 5 years that I've been on the crusher. The bigger the equipment you run the bigger the breakdowns! just raises our cost per ton crushed this year
  16. dieseldog
    dieseldog She idles just fine . . .
    1,873
    4,207
    Jan 25, 2005
    Houston & BFE
    Classic failure pattern on that shaft.
  17. -Spike-
    -Spike-
    6,693
    440
    May 26, 2005
    Phoenix
    Was there something you could do before it broke? Is that breakage caused by something the operator did, or just normal wear?
    -Spike (Can't imagine what you could do wrong to a crusher...)
  18. 3_puppies
    9,916
    845
    Dec 2, 2002
    Helena MT
    tried to crush a non-rock
    well we think this was the final straw, back when they first got this cone they tried to crush a 992 loader tooth. probably 10 years ago.
  19. JRFJ4-
    JRFJ4-
    696
    1
    May 11, 2005
    NORTH ALABAMA
    What material
    What material is that shaft made out of. I'd send it out for chemical analysis. It doesn't show alot of twisting from the picture.
    What kind of crushing are you doing?
    I worked at a foundry that made grate bars, bowls, mantles, jaws, screens, drop crosses and hammers for mills. I miss that job sometimes.
    JR
  20. 3_puppies
    9,916
    845
    Dec 2, 2002
    Helena MT
    we take big rocks and make 'em into small ones! concrete and asphalt material mostly. some road base also
    wouldn't be much rotational force as the shaft is solid mounted in the main frame and the mantle spins on it. more of a shear sideways force trying to force a big non rock thru.
