Anyone out there know if it is possible to set up a H55F 5 speed tranny to a orion tcase?
You are correct about the split tcase! I know h55f exist for 1piece cases, just never seen one, dont think they made it to the US. . Was looking for other options if possible. I would like a lower 1st gear and a 5th gear option and want to keep everything toyota.
Yes rig is posted and just testing the waters.
I would call advance adapters and talk to them about your options. I am pretty sure they have different input shafts for the orion. So you may have to change your input shaft if you already have a orion.Anyone out there know if it is possible to set up a H55F 5 speed tranny to a orion tcase?
I think the orion is either 16 or 19 spline...well I know it's at least either as I have both
So the input shaft is not the issue just a adapter to bolt the Orion to the H55F? Or does the Orion come in a version to replace the split transfer case? But the 83+ have provisions to oil the fifth gear in the H55F.
X2...that's what I was thinking, how to attach the transfer case and what about the 5th gear oiler.
the split case is a very durable transfer. does the orion have a lower low range?
Here it is , I found it
77 fj40 , 1kz-te , h55f , orion
