H55f Run-in
Cruiserdrew
On the way there
Sacramento, CA
My driveshafts are going back in this afternoon, so I'll have my H55f on the road!! I was wondering if the new tranny needs a break-in period. I filled it with gear oil yesterday, and let it idle for a few moments in each gear. I can do more of that if it's benificial. By they way-I had no unusual noises, or squealing from the piolt bearing that others have reported. I let the clutch out and the t-case output started spinning-a good thing! The tranny shifted smoothly in all gears, except 3rd which was notchy the first shift, but now seems fine. Can I run it immediately on the freeway, or should I drive around town a bit like you would a new differential?
My plan is to run it a few days and change the gear oil in both tranny and t-case. THere is a fair amount of moly grease in the tranfer from the rebuild and I want to flush that out, plus any dirt I might have introduced by having it apart.
Radd Cruisers
Vancouver Island BC Canada
No real break in, guess you could open the drain plug quick and put a finger over the hole and check the magnet for filings, otherwise I prefer a goo brand of synthetic.
Could of taken a bit to get the oil up into the third synchros, pretty big cluster.
Only places I like synthetic is the gear boxes and diffs, long term oil and synthetic does not like to mix with water, so I have been told.
Rob
Tapage
Club 4X4 Panamá
Panamá
" No real break in, guess you could open the drain plug quick and put a finger over the hole and check the magnet for filings "
Agree .. but important thing about checking the magnets. I thought that some miles around the town is enoough to " brake in "
