Hey guys, my Bj60 with 230,000km is running into a transmission issue. I just finished a 2300km road trip, and I started to notice a vibration while cruiser at certain rpm, pretty mild, like a stranger wouldn’t notice at all, but when you drive it all the time you notice subtle changes like that. Also, once it’s warmed up the transmission makes more noise in neutral, like if you’re parked beside a barrier and the sound comes back at you it’s pretty loud, sounds almost like a clacking with a whirring. When you push it the clutch it goes completely quiet, so I’m sure it’s not the motor. I pulled the drain plug to check and sure enough there is a decent amount of glitter in the oil. It’s not silver, more like clean oil with a tiny bit of shiny-super fine sand in it. I was using motul 80-90 synthetic gear oil, rated for both GL4 and GL5.
Im curious if any of you can give me a good idea of what’s likely wearing out in the transmission, and can I put a thicker oil in there and drive it for the summer before I tear it apart or is this thing totally untrustworthy and likely to leave me on the side of the road soon??
thanks for your help!!
