H55/ T-Case Gear Clanking Sounds.... (1 Viewer)
Franklin, Massachusetts
Figured I’d bounce this one off everyone to see if anyone experience a similar issue
I’m hearing very loud gearing sounds when I’m coasting in the truck. The higher the speed the higher the frequency.
It occurs whether the truck is in gear or in neutral, and engaging the clutch has no effect on it.
Note:
U Joints are three weeks old (no play)
Trans and t case fluid was changed about a month ago
Video of the sound as it occurs
H55 / T case sounds
OSS
Oblivion
whatever is causing that racket - it's not good. Guessing what it imight be before disassembling stuff won't accomplish anything. Transfer case and transmission and clutch parts need to be inspected. The culprit will likely be easy to see
San Diego, CA
Unfortunately, I just went through this. For me it was my trans but based on the frequency of the thud, it may be your t-case. Especially if you get the sound rolling through all your gears.
When I did the same test, running through all the gears with t-case in neutral, then the I heard nothing. It was only when there was load on the driveline when I heard the sound and only in 3rd. I may have video recording of mine and the sound was identical but thud was more spaced out but the same "thud" sound.
Klamath Basin
Re-reading your post and you say it happens with the trans in neutral too? I assume the truck was stationary when you were rolling through the gears with the tc in neutral? Does it coincide with engine speed or ground speed? If it does with the trans in neutral it wouldn’t be t case unless the truck was also moving.
rhah
Admit it, your cruisers jealous
ottawa, kansas
Noise in all gears, lifted not moving, transfer in neutral
noise reminded me of a broken flywheel,,, but I’ve not herd of that on bigger trucks usually small cars or automatics...
