Not on the website.... can not find an input shaft for sale for a BJ engine, only H and F...
my mistake, I forgot you're after a "B" input.
Is the input shaft bad or just the bearing and snychro?
I wouldn’t consider the 34mm idler to be a major problem at all.
Keep in mind that you’ll want to use the output flanges from the 40 transfer for the correct bolt pattern to match your driveshafts.
Yes it seems that is the case.... for now Mike at the workshop who does custom stuff and is a star took the B end and mated it to the H plate to make a Frankenstein input shaft retainer... half H and Half B... seems to fit ok.... I will hunt down the correct one to fit at a later date but can make progress now.....The input shaft and bearing retainer are both longer on the B series transmissions than they are on the F and H series transmissions.
The OD of the bearing is larger on the later transmissions and I’m not sure if the bearing retainers are swappable between early and later transmissions.
do I need the BJ60 input shaft cover?
Looks like you have a solution for now....BJ60's weren't marketed here, were they offered with the H55F ?
