lelandEOD
I’ve decided to rebuild my H55 and want to source the appropriate tools (bearing and gear pullers or suitable substitutes for the factory SSTs) necessary take this transmission apart and rebuild it correctly. I have a couple large generic gear pullers but they won’t work as there’s not enough length to pull against the input and output shafts. I’m curious if anyone can share part numbers of off-the-shelf pullers or other tools I should have to make this rebuild easier. I’ve been around long enough to know that jobs like this are usually much easier if you just have the right tools on hand. Dremeling bearing races and yanking on gears with pry bars doesn’t sit well with me.
And... tech threads without pics, suck.
So Far, the disassembly has been relatively uneventful with the exception of one transfer case bolt head that was rounded and I was unable to get it loose. I ended up drilling it out and will have to use a broken bolt extractor to remove the remnant. Looks like this case will be getting at least two time-serts as one other bolt galled the threads when I pulled it.
