H41 on an older F
Utah
Has anyone put a 41 tranny on an older (67) F? Will they just bolt up?
I have a 2F bell housing too. What about the T-Case. Can I use the original?
Hi All:
Yes, you can bolt an H41 tranny to an older "F" engine but you must use a 2F bellhousing. Either clutch assembly - three speed or four speed will work as long as you use *all* of the associated parts.
Regarding the t-case, the three speed 'case can be used but it will require mating it to a four speed tranny, which is not a straight bolt-on (do a search, you will find lots of info.)
Regards,
Alan
Alan,
Thanks for the info.
jj
