- Thread starter
- #21
Oh right. That option totally slipped my mind.
You can pull the plug and redo the ends. I did that w/ my fusible link. Actually reused the female ends too. The ‘plug’ that holds the ends in is just a thick chunk of rubber. Pry it out, cut the wires and redo the ends and stuff it back in.New used relay put in and still doesn't work.
Only thing I can think of is that its the green plug thats got a bad connection.
I'll take a look again but I did not see anything there. Was it immediately behind the fuse panel?My 81 FJ40 had an in-line fuse behind the dash; I was surprised when I found it since I thought all of the fuses were in the panel. After swapping in a good fuse, my carb cooling fan started working again.
