- Joined
- Mar 3, 2015
- Threads
- 68
- Messages
- 380
- Location
- Lonely Nevada
- Website
- www.willenosphotography.com
In the process of installing my new radiator. Drained the coolant and upon inspecting it for whatever.. found that it is full of sand-like grit. Well maybe a little finer than sand. Also found it pooled up in the low part of the hose elbows. The only thing I can think of.. that it is rust from the cooling passages in the block. However I inspected the previous coolant when it was drained in prep for my first radiator replacement. No grit! Possibly it was hiding in that replacement radiator. I flushed it before it before it was installed. However I didn't really put a lot of effort into it as it was a brand new radiator.
SO other than rust in the block.. any ideas as to where the grit came from? I did't really need to pull the water pump to install my new radiator.. especially since I went thru the whole system with new parts 20k miles ago. But I will be pulling the pump to have a look at the internals for any scoring or grit in the seals. Guessing the same with the thermostat as well. Not much to go wrong with one except fail of old age. But...
