gringing on my new ring
in the garage
gotta get the retaining pin to slide past the ring.
woooohooooo a little at a time.... :eek: :eek:
in the garage
just this one
i do all my slider cutting and grinding with it.
sears craftsman.....
in the garage
Ha Ha I Just Got That Doc!!!
krzyabncanuck said:
What gears are you grinding on ( size ) I had to do that to my 4.56 and 4.88.
4.88's
did you have to GRIND to get the c-clip in for the axles?
krzyabncanuck
USFS HOTSHOT
NC
Yea, I sure did and was not too happy with that but that is justn a fact of the 4.88s. I've had them under for about a year now and I pulled the cover about 2 weeks ago and they were still wearing good.
KLF
Frame waxer
Southern NH
Here's what my 4.88's looked like after grinding to get the crosspin into an ARB:
I also had to take a little bit off the inside of the teeth in order to get the thrust block to slide in:
I used a 3/4" sanding drum in a die grinder, with a fine drum on it, worked slowly till things just barely fit. Make sure you clean it well, remove all the grinder dust.
Mace
rock scientist..
Staff member
s-Moderator
Las Vegas
Grinding on a cruiser center is no big deal... You have to remove almost one full tooth on 5.29's
I have not heard of one single failure..
in the garage
that awsome
one full tooth :eek:
it's good to know,thanx all :cheers:
Dallas
How many miles have you put on it? My concern was reverse. I have a great contact patch on the drive side, but a little less on the coast. I had to grind two teeth for the pin and four for the sleeve.
nuclearlemon
not an addict
Moderator
windy wyoming
been to maob and back twice and they were in my dd for about five months.
