Grinding sound along with vibration
Discussion in '80-Series Tech' started by Vanny, Aug 11, 2018.
  1. Vanny
    Vanny
    1,141
    81
    Jan 12, 2006
    Ladner, BC, Canada
    I have a grinding sound along with a vibration on deceleration when over 80 km/hr. Have had a part time kit in since 2007. Had the driveshaft straightened and balanced last week along with new U joints. Any ideas what else it could be? What should I be checking?
    Am pulling a trailer from Vancouver to Drumheller, Alberta on Sunday. Crossing my fingers everything holds together.
  2. Rifleman
    Rifleman
    1,615
    1,122
    Feb 4, 2015
    If it were me, instead of crossing my fingers hoping it holds together, I'd be spending time BEFORE i left on this long trip to find out what's causing that grinding noise, or using a different vehicle to tow your trailer. I've found it's alot easier, and far less EXPENSIVE to fix those kind of problems at home. Instead of on the side of the road, or in some strange repair shop charging me 100 bucks an hour labor. YMMV
  3. bajaphile
    bajaphile Boojum Hugger SILVER Star
    1,897
    Media:
    7
    1,172
    Apr 6, 2008
    Solana Beach, CA
    Was the vibration/noise there before you had the driveshaft and u-joint work done?
  4. jjdeneen918
    jjdeneen918 SILVER Star
    383
    101
    Jul 23, 2008
    Long Beach, CA
    Had the same issue recently. It was the front drive shaft, but sounds like you covered that.
    My next guess would be wheel bearings...
  5. Michael Hanson
    Michael Hanson
    8,845
    Media:
    9
    Albums:
    2
    359
    Oct 30, 2007
    Plano texas
    Hi, Check fluids in transfer case and differentials. Mike
  6. LINUS
    LINUS Waiting for the Great Pumpkin
    4,692
    Media:
    40
    Albums:
    3
    3,164
    Mar 29, 2003
    PNW - WA
    With your 4” lift, you could have problems solved by:
    -DC fr driveshaft
    -Pinion bearing preload on 3rd member (RR normally) - ‘grrrrrrrr’ -sound on decel/off-throttle
    -Pinion angle / method you used to correct it.
    That’s just off the top, let alone birfs, spindles/FR wheel bearings worn.
    BILT4ME likes this.
  7. ewillis
    ewillis SILVER Star
    2,423
    3,611
    Oct 11, 2013
    Dante's Inferno, CA
    Dry spindle bushing...
  8. Vanny
    Vanny
    1,141
    81
    Jan 12, 2006
    Ladner, BC, Canada
    I have had it part time since 2007 so it isn't the front . With the travel trailer attached the vibration /noise was actually less. I am wondering if the drive shaft should lengthened since it's better with the rear weighted a bit. Survived crossing the Rockies .still somewhat concerning though .
  9. Vanny
    Vanny
    1,141
    81
    Jan 12, 2006
    Ladner, BC, Canada
    Definitely not the birfs or wheel bearings. I will have to check the 3rd member.
  10. Vanny
    Vanny
    1,141
    81
    Jan 12, 2006
    Ladner, BC, Canada
    Will check that.
  11. Jgunner
    Jgunner
    624
    657
    Sep 4, 2017
    Arizona
    I have the same thing right now. I think its my driveshaft, at least hoping. New parts everywhere and under 300 miles so far. I had it before ALL new front end parts but it was more faint. Could be driveshaft is in wrong phase or needs new u joints, as i greased it as it was all apart.
  12. Jgunner
    Jgunner
    624
    657
    Sep 4, 2017
    Arizona
    Gonna yank my ds and lock cdl and see what happens!
  13. LINUS
    4,692
    Media:
    40
    Albums:
    3
    3,164
    Mar 29, 2003
    PNW - WA
    @Vanny -
    If you want good answers, how about breaking down in detail your drivetrain mods?
    I had to read your sig to get the 4” lift that can be a cause of issues, plus it took an answer for you to give up that you PT’d the 4WD/AWD.
    Not being salty, just saying unless you list all your mods nobody but you will know ‘em. Just a suggestion.
