Searched and can only find topic not specific to compressed suspension.
When driving and going into a dip/ low spot in road that compresses the suspension significantly (not bottoming out or anything) I can hear a grind that is almost gear-like and wondering if my birfs are jacked up or if it may be from somewhere else- it's not tire rub.
To start: '94 | I've a Woods front DC DS, 3" lift on 33s (grabber at2)
The driveshaft is new | I've recently flushed the front diff (75w-90) | filled the knuckles thru the port about ~3/4ish full to buy some time (no leaking) | greased the rear shaft
I'm doing full front knuckle maintenance and all gear oils this wknd and wondering if I should delay if it's something else to handle it while its under the knife...
Trying to think of all possibility's here that would be "affected" by compression of the suspension. I do get the "clicks" on locked turning and hard acceleration- which is why I'm doin the knuckles but its a completely different noise.
