Good day all
Just bought my first fj60 cruiser at a bargain
But the cruiser was standing for more than 6 years and when we towed it to the workshop we tried to start is but no luck checked the firing order and it was a mess
After sorting that out still nothing checked the distributor found out its an electronic one running trough the resister coil setup
So changed up the coil and then we started getting a backfire trough the carb that's after we changed the firing order so started playing with the timing but no luck on starting it. So we started playing with the firing order if we connect the firing order 180° out its wanting to start and the backfire is gone then we checked the compression of each cylinder and found that they are all at 4 bar (58psi) all the same can this be timing related? Or sticky valves?
If we crank it with the started it doesn't want to start but if we pull start it starts but dies after about 2min running..
