Okay let me preface this by saying I'm the dumbest guy I know.
I am just about ready to drag the transmission and transfer case out and install that (alone too)
I am trying to get the wiring sorted out and have read as many threads as I could find and (at least to me) they all seem a little different.
1. So what you are looking at her are the 2 black wires on the Trans for the reverse lights.
2. The blue to gray connector, 3 prong, 2 thick wires (1 black, 1 white) connected to bypass the NSS.
3. The old Auto Trans temp connector that was suggested where to connect the thin black wire from the 3 prong blue to gray connector. (1 yellow/red wire, 1 yellow/green wire)
4. The same blue to gray connector, thin black wire connecting to the same old AT Temp connector. Also the blue wire from the withe to gray 2 prong connector, both connected to the appropriate pin to match the color suggested in other posts.
5. The red wire from the white to gray 2 prong connector which is supposed to be capped.
Right here I would like you to read the first sentence of this post over again before proceeding.
How in the hell is reverse light going to work? What connects to the 2 black wires on the transmission?
