Grease Zerks
Berthoud Colorado
Website
www.w2m.com
:cheers:
how many grease zerks are there under the mighty 97 TLC........
Good question.I found 4, and after greasing most of my clunking,loose feeling play was almost gone.I found only the 2 u-joints and the 2 driveshaft zerks. Vince
wouldn't that be 2 U-joint and 1 DS per shaft?
6 total? :cheers:
Dan,No I meant 1 per u joint =2 and 1 per driveshaft =2 for a total of 4?...Now ya got me wondering and my wife has the cruiser at the moment NOOOOO!..Seriously is there 6 total? It's killin me ya know. I have a '97 mind you. Thnx,Vince
I just greased the 96 last night and changed the diff and transfer case oil and DK is right .
Stock fzj80s have 6 . Each driveshaft has 3 (1 for each u jount and one for the slip jount )
Hell, you did 4 times better then the dealer :) I got my truck from as they greased the big goose egg :doh:
So go out there when the wife gets home and find the other 2 :D
>> how many grease zerks are there under the mighty 97 TLC <<
Six.
-B-
Ok,I'm sobered up now and yep theres six :p
What kind of grease should I be using on the driveshaft ect....
Bear-in-mind that I don't want to switch back and forth the grease that's in my gun. need to stay constant. Wheel bearings are packed now so that's not an issue.
Also since I already have grease in the u-joints, does it matter if I switch to another type? like switch from dino to synth?
R
U-joints shouldn't matter as you can pump new in and watch the old come out. :banana:
The driveshaft itself is where you need to wait and be patient...don't overfill that puppy or you will not have a good day. BOOM! :eek: ;)
**edit**
oh, and to answer you on the type of grease....I have this one grease gun I have been using for all zirks in all trucks for so long now I don't even know what it is. :cheers:
