Do you merely press the heater and oil unions into the cylinder head or do you need to apply some type of seal? Thanks, ahead of time!
I'm talking about pushing the unions into the cylinder head.Press and clamp? I usually use a drop of Dial liquid hand soap to motivate the hose over the barb.
Thank you.Those fitting are pressed in.
I would use some water pump/thermostat housing sealant on them.
Thank you.Usually press fit is good enough, however I'm going to use some locktite 638 retaining compound unless I thread those 2 ports for AN fittings. Still on the fence for my head.
Unfortunately, I don't have pictures. I knew there would be a few on here that would know what I was talking about from just the description. I'm with you - I need pictures.Pictures really help us with info.
