Good Smog Numbers - CA
La Mirada, Ca
Curious as to what other people's passing smog numbers look like. pics or scans of the smog test sheet would be preferred.
august 2013: 1988 with a fresh oil change, tuneup (plugs, wires, pcv valve, fuel filter and sea foamed), and valve adjustment.
'86 FJ60
275K odo
Leaking exhaust valves (all) both tests
Low compression = 110 psi all
Head has since been rebuilt. Curious what 2016 results will show.
Also interesting is that the 2F is allowed higher Max values compared to a 3FE.
Also a bit odd that both tests were done at the same shop, but the RPM is different for the 15 MPH test each year... hmmm.
This is a good idea, but my only request would be that 60 owners in particular please add an asterisk to their numbers where applicable. If you know what I mean, you know what I mean...
Output Shaft, why did you have to test in two consecutive years ('13, '14)?
