Going All Over The Road!
Discussion in '60-Series Wagons' started by Nightshadow, Feb 28, 2007.
  1. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    Well,
    I just went to get my cruiser out of the shop today, and as I was driving it home, every time I would hit a little bit of slushy snow in the road, it would throw the front of the cruiser all over the place.. I know what it feels like to hydroplane, but this is way worse then I've ever felt. Could this just be a camber issue/allignment issue? I have it lifted with homemade shackles, about 2", and the sway bar endlinks are stock size. Also, My front shocks are completly shot, and very stiff. Every suspension component, minus the rear shocks are also as old as the cruiser itself. Any ideas?
  2. REKCUT
    REKCUT SILVER Star
    3,753
    Media:
    103
    Albums:
    4
    152
    Jan 5, 2005
    Rogersville, Mo.
    I would lift it and check all the bolts. Springs, shocks, tie-rod ends, anything I could touch under it.
  3. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    Good idea. I am going to be changing out the front shocks/steering stabilizer anyway :)
  4. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Sounds like tie rods. If you confirm thats at least part of the problem I've heard you can upgrade to 80 series tie rod ends....just something to think about.
    Toad
  5. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    I'll definatly take a look at those as well...
  6. brian
    brian SILVER Star
    8,716
    2,148
    Feb 7, 2003
    lebanon,pa
    so it's lifted two inches just with shackles?
    how long have you had them on?
  7. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    I've had them on about 2+ years, but it just started doing this... I never had a problem with it before...
  8. John Smith
    John Smith In the garage
    4,201
    Media:
    6
    Albums:
    2
    257
    Jun 7, 2004
    Maryland
    What did you have the "shop" do and did it never do it before they got their hands on it?
  9. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    Well, I had the shop weld one of my motor mounts back about 1/2" as I could'nt get the new motor to line up properly... I doubt they touched the suspension at all, and before I brought it into the shop, I had'nt driven it in quite a while...
  10. corsair23
    corsair23
    2,172
    10
    Apr 3, 2006
    Littleton, CO
    Maybe this is a stupid question but had you ever driven your 60 in the snow/slush PRIOR to this point with the 32x11.5's on it?
    Wider tires will often get 'grabbed' by the slush in those conditions as well as have a tendency to follow ruts. Put the two together and without a good steering stabilizer (sometimes even with a good one) the steering can get real squirrely.
  11. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    Good question. Yes, I have driven i in the slush and snow several times before, and it never seemed to do this... I just got a new ironman stabilizer, so I am sure that will help. You are right though, the tires are different then when I had the 30's on there... I also just found one of my sway bar end links to be loose.. Thanks
  12. svo_jon
    svo_jon
    261
    Dec 22, 2004
    Bend Oregon
    What kind of tires and how much tread? Wore out A/Ts don't like slush so well
    Jonathan
  13. Nightshadow
    Nightshadow
    89
    Sep 25, 2005
    Grants Pass, OR
    60% Tread left on widetrack radial baja m/s ...
