Gnarly alert; heater blower motor assembly
Rossland BC
If you have not looked at the inside of your heater blower assembly, you'd be surprised at how gnarly it is inside.
What started as a quick fix to seal the assembly to the side cowl ended up in a total re and re.
Evidently the material/sealing grey foam has less than a 40 year life span. Not surprising, but hidden until you open it up.
Essentially a combination of grey desiccated dusty degraded foam and greasy grey degraded foam.
Crack into it, you'll breathe better and you'll get a much improved air/heat delivery.
i used 1/8 cork on both sides of the internal baffle and varying thickness and widths of peel and stick "weather stripping"
to achieve a seal btw assembly/side cowl and assembly/fire wall side of cowl.
Wausau WI
You mean this job? 🤪
Rossland BC
not the heater box, ......the heater blower assembly under the hood
the source of most of the grey mess that ends up in the heater box.
i didn't take a single pic, wasn't really planning on digging in that deep until i did.
Wausau WI
Central WI is a big sand flat...I'd love to know how many pounds of sand I removed from all the nooks and crannies.
Same with dog hair... 😆
