I'm finishing hooking up my TBI and am wiring my alternator. I have a couple questions. I'll start by saying its a three wire alt with batt, red wire, and brown wire. I've deduced that on the stock wiring harness White with blue stripe goes to the batt on alt and the red (terminal 2) gets jumped to the batt and terminal 1 (brown wire) is hooked to the black with yellow wire at the fuse block for the ignition 12v. Now the questions:
1. The white with blue wire is a little small (guessing 10 gauge) for the increased amperage GM alt. If I don't use it and run a 6 or 8 gauge wire direct to start will it cause anything not to work? I know theres a white/blue wire at the fuse panel. Or would you just run the smaller wire?
2. The brown excite wire requires a resistor (usually a light). In your experience will it work without the light hooked straight to 12v ignition (and if you wired in a light, where did you put it?)
