So the PO, or more likely the PPO had an overheating issue (a cracked headgasket as it turns out)
He Couldn't get the thermostat housing off
This is after flushing it 3 times
Dunno if you can see but the hose too, is solid with what I guess is stop leak of some kind...
The lower housing has yellow stuff all over it too...
Between the big hose and the housing was like a 1/8 in crust of this stuff. which is why it was all lumpy, and clamped in weird.
So much for a quick fix... off to order the upper housing and the water by pass hose
Otoh, after this it'll be better, so that's to look forward too.
Question: Am I correct in assuming this could be the cause of the original overheat the popped the head gasket?
Thanks,
E-
Thanks,
E-
