A few days ago I started chopping the rear quarter panels. I went up the body crease and ran the line straight all the way. Trimmed the body mount support, will cap and weld separately before sealing up the rocker. So now I need ideas on the back. What can I do to make this higher? The frame seems to hang really low out back. Is there anyway to gain a bit more clearance here?
I've seen Kirk's badass build but it seems like most of the clearance gained is on the sides and not out back. I don't mind cutting and relocating the body mount, but it seems like the body crossmember and frame hang low no matter what you do. I also don't mind shaving an inch or two of the tailgate either. I'm picturing 2x6 planks under the rear quarters and under the tailgate. I'm just not sure how to get more ground clearance, or if it's even worth the effort.
This is where I'm at so far
Left vs right. Lots of room on the left, but you still have frame and body mount which hangs really low.
