@Qball , you posted the part # for the maf sensor, but do you know what cars to find that on in the salvage yard? I know I can find it doing a search, but just looking for the easy way, thanks.
Ok, found that ok but what about the sensor itself not the housing, the used Toyota part?Somebody posted a link to ebay for a Subaru part which is a direct fit. Might want to look at that one.
Perfect, I have a friend with a salvage yard that has a 2000 4runner in it, should be right, I'll check. The last three trips I've been out there he has sent me away with no charge - switch blanks, hazard switch, plugs, bolts, nuts, etc. Maybe I will have to give 5 bucks for it.Look for 22204-21010, just about all time period Toyota use that sensor including Tacoma, Corolla, Camry......
Anybody have any info on re-wiring the connector for the new sensor? If I remember you have to swap some pins around?
What is your gas mileage now?That's the one!!!
What was the mileage initially without all the gear? I’m looking to add MPG vc I’m averaging 10-11The usual really bad 10-11MPG. It is expected as the old girl put on more weight as time goes. Added tons of stuff since the thread was active almost 3 years ago. I added a bumper, winch, roof rack and much more but I also moved and live in an area with a bit more hills so not surprising. I still think the upgrade is worthwhile because even with all that weight I put on she still goes fine.....relatively speaking.
