Hi,
I have a few clutch questions:
1. How often do the "fingers" from the clutch pressure plate brake or become damaged? Is it still a common problem nowadays? How many miles can you go before broken fingers become a likely problem?
2. How many miles can a car go before the flywheel needs to be machined (refacing)? Or is machining of the flywheel not performed anymore nowadays?
3. If the clutch is slipping, is it possible to replace the clutch disc alone and not the pressure plate (I guess that the disc is worn MUCH faster than the pressure plate)? I know that most people would say: Change both bearing, disc and plate at the same time while everything is disassembled. But from a technical point of view: Will clutch engagement be bad if only the disc is replaced - will the overall performance of the car bed bad?
To conclude: How far can you go with the fewest replacement parts (not observing labor).
Lucas
Lucas
