I'm installing factory power steering on my 1982 BJ42. I've rounded up all the parts I need and have mounted most. The pump/reservoir setup was off a 70 series which means they are seperate from each other. When selecting a spot to remotely mount the reservoir, should it be above the pump? Does the fluid coming from the reservoir gravity feed to the pump or is the pressure in the system sufficient to deliver the fluid from the reservoir if the reservoir is mounted below the pump? Trying to figure out the best place to position the reservoir. I notice in pictures of 70 series, the reservoir looks to be mounted high on the firewall. Thanks for any help....Greg
