Dave, this is great news for those who want a simple and easy way to swap an LT into their cruiser. Just to let you know, it's exactly the same for those who have a 105 cruiser. So your kit should work on both chassis as they are identical for the most part.
do you know if the 6l80 and 8l90 have the same output? So can your Tcase adapter fit either transmission?
Ah too bad. I thought you'd have it running by now. The 45 will be fun for sure!
I kept the stock L83 fuel rail and it's non return. So the regulator is pre fuel-rail. I'm using this regulator
Compact EFI Regulator and Fitting Kit
P/N 13130 Compact EFI Regulator and Fitting Kit 13129 EFI return style Regulator (3) 15606 Fittings (1) 15633 Pressure Gauge This product is not legal for sale or use on emission-controlled vehicles except when used as a direct replacement part matching OEM specifications.aeromotiveinc.com
I think If I did a return-less fuel system it could act more like O.E?
Great news on the 105, thanks for sharing that. I'll have to do a bit of research on the 105 and see how close to drop in this would be for that platform.
Our adapter only will work with the 8L90 and 10L90. Everyone wants more gears right?
