Gen 1 Slee Arms + 6" springs...
Discussion in '80-Series Tech' started by DanKunz, Mar 4, 2007.
  1. DanKunz
    DanKunz SILVER Star
    9,709
    Media:
    2
    Albums:
    1
    1,006
    Feb 7, 2002
    Woodstock, GA
    I have the adjustable slee arms on my truck and 6" springs...I was wondering if I couldn't simply unscrew them a bit to get better angles in the front and what lift they were made for initially for correction..it seems as though I am out of spec up there, but I haven't gotten measurements taken as I plan on adjusting everything (panhards, etc) first...and I am doing that after I get the new tires this week.
    Any input is appreciated.
  2. Skim
    Skim
    886
    Oct 4, 2004
    Benicia, CA
    I have the same arms on my 80.
    I contacted Slee with a similar question.
    He said the original arms were built to meet the original purchasers specs. (lift, etc.)
    You should contact Slee and ask him.
  3. Nay
    Nay
    4,586
    496
    Aug 17, 2004
    Colorado
    What spec is not aligned? Any front arm adjustment should be done for pinion angle (lest ye have vibes on a full time front end), which is the primary adjustment and caster follows. Assuming a DC front shaft, do you have something other than a zero degree axle end u-joint operating angle?
    What is the adjustment you can make on these arms that would affect pinion angle and therefore caster?
  4. DanKunz
    DanKunz SILVER Star
    9,709
    Media:
    2
    Albums:
    1
    1,006
    Feb 7, 2002
    Woodstock, GA
    Thanks Skim. Every time I do that I end up buying new stuff :)
    I guess I could sell these arms for $ and go with the new hotness of those 6" arms. Sweeeeeet lookin too!
  5. concretejungle
    concretejungle SILVER Star
    9,517
    743
    Oct 27, 2003
    North Cadillac
    but dan, the arms you have are "supposed" to work for you lift. Maybe add some CC bushings if you are short on caster.
    I am assuming you were wanting to "un-screw" them to add some length?
  6. sleeoffroad
    sleeoffroad Supporting Vendor
    6,137
    977
    Mar 27, 2003
    The arms are not adjustable for length. The threaded piece relieves some of the twisting forces on the arms when articulating. You can unscrew a little to gain length but not more than 1 revolution from fully closed.
    As for correct for the lift. Those arms were custom made for specific lifts. If your truck went up with the 6" springs, then you are probably a little out of caster spec.
  7. DanKunz
    DanKunz SILVER Star
    9,709
    Media:
    2
    Albums:
    1
    1,006
    Feb 7, 2002
    Woodstock, GA
    I suspect I am out of spec. Will know later in the week, getting everything measured. Worst case I can just get some of those new fancy arms and sell mine for someone who wants Js and spacers :)
