- Thread starter
- #21
before actual leaking, yes it was rising levelSo the theory is that the transmission is leaking fluid, but the fluid level in the transmission is going up??
I divide situation on 2 phases
1. Level started rising around 200 miles slowly after all maintenances, then first leaking on ~600 miles
After firs leaking level continue rising, but there was no leaking at all for about ~600 miles
2. Second leaking and it was continuously leaking, i did check the level but as you guess it was on running engine but it was on cold, where level was high than max of cold.
After I saw that leaking continuously, I stopped driving the car, only small 2~3 miles to service.
So how I did the measurments of the oil
Start driving outside the town, ~20 miles, then a bit in the town ~15 mins with trafic
And then in my garage when car is sitting 2~5 mins in idle shifted on Rear. Outside was not cold, it was spring.
I hope next week the mechanic in service to start working on it, so I will have some info to share.
