Hi All
I have resently put a H150 gearbox, soursed from a FzJ79, into my HzJ76. The engin now seems to be tilting backwards a bit more than before the swap.
I had to use the FzJ mount as HzJ ( R151gearbox) mount did not fit the new box. I then tried to compare info on the FzJ and HDJ mounts, in case the HDJ mount is taller, which would slove my problem.
Trouble is that I can't find any ToyoDIY on these mounts. I have found that the HDJ mount is 12371-17120 and that this is also the V8 mount, but does not mention the FzJ so I asume that they are different. The gearbox is the same and the crossmember is the same, Sooo, i asume that the diference is in the hight of the mounting.
Any further thoughts, info part numbers or pictures which would help would be appriciated.
