This will be pretty short but I wanted to get some of this up. The front e-locker is essentially the same as the Taco so there is plenty of info out there. However, there is nothing that I was able to find in regards to setting up the rear with an e-locker.
Quick fill in...I went up north to Poser's (LCR4WD) to have him setup my gears. Steve is pretty well known in the 40 & 55 world and is wealth of knowledge when it comes to Toyota's, fabricating and so on.
To the meat and potatoes. The rear diff uses shims to setup the ring gear position and carrier bearing preload. Once Steve found this out a little drama ensued. It took a little while to get the sets of shims as there was not two full sets in the US. Yes, you can use the existing shims but you run the risk of it not being done to spec.
Steve, add in whatever you want or correct anything needed. I know you have some other pics as well.
This is a little info so when you're shelling out the Benjamin's you know what going on.
This first pic is of the 3rd member on the bench showing the reason why shims are required. With the shift fork outside the carrier there is no way to have a standard Toyota adjuster.
This shot shows the shim installed.
Shot of the rear locker assy
Rear housing and shift fork
A good shot showing how the shim is installed without the cap on. There are 23 different shim thicknesses that can be used for the setup.
One last check of the pattern before it's done.
Just a few random shots
diffence between 4.11 and 4.88 pinion
