Gear Ratio 4.11--4.10
Discussion in '60-Series Wagons' started by tlcmx60, Mar 3, 2007.
  1. tlcmx60
    tlcmx60
    14
    Sep 2, 2006
    Hi, i,m going to upgrade my fj60 1982 diff gear and have 2 choice, (4.10 from a 1992 80 complete 3rd member two rear or 4.11 from a 72 fj40 only ring and pinion) Some body can helpme for the best selection, and this fit to my 60?. thanks for your help. and regards from baja.
  2. Godwin
    Godwin Resident Herpetologist SILVER Star
    4,264
    2,863
    Dec 4, 2004
    Alabama
    You do not want the diff from the 72 FJ40. It has a coarse spline pinion and you'll encounter flange differences. Don't know what, if any, stumbling blocks you'd encounter with the FJ80 diffs.
  3. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    14,870
    3,478
    Mar 15, 2003
    Sacramento, CA
    Use the later one. The 72 is a coarse spline pinion and significantly weaker.
  4. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,398
    1,850
    Feb 17, 2002
    Las Vegas
    92 80 rear is a FF application, you might get a headache with the spiders if you are just swapping in the third..
  5. CardinalFJ60
    CardinalFJ60
    1,169
    49
    May 15, 2003
    Louisville, CO
    I'd look for ones from a 62
    I did this on mine...got thirds from a 62. Actually, I got two "front" thirds IIRC. less wear and tear.
    HTH
  6. Cruiserdrew
    14,870
    3,478
    Mar 15, 2003
    Sacramento, CA
    No it isn't. The FF started in 93. The 91 and 92s and some 93-94 have semi-floats.
  7. Mace
    21,398
    1,850
    Feb 17, 2002
    Las Vegas
    then he should be golden..
