Gear Oil, what are you running?
Discussion in '60-Series Wagons' started by Acadia, Feb 16, 2009.
  1. Acadia
    Acadia
    437
    2
    Jul 10, 2007
    Olathe, Kansas
    I am trying to find out what everyone is running for gear oil? I did a search and it didn't bring back much for results:(
    My FSM says I should be running SAE 90 in the diffs, transmission and transfer case but I haven't found anyplace that carries straight 90w. at least nothing that is GL-5. TSC carries 90w GL-1 straight minerial oil for ford tractors.
    So I have been running 80w-90 in all the above. anyone see any problems in doing so, or is there a better option besides 80w-90?
  2. REKCUT
    REKCUT SILVER Star
    4,003
    Media:
    103
    Albums:
    4
    361
    Jan 5, 2005
    Rogersville, Mo.
    80w-90 is what I am running.
  3. John Galt
    John Galt
    1,378
    62
    Jul 13, 2008
    Coldest N. America
    Amsoil or Castrol full synthetic 75W-90
  4. sl33py
    sl33py
    2,160
    8
    Jan 8, 2004
    Emerald City
    same here 80-90w. going to go to mobile 1 syn at next change on the new h55f.
    rob
  5. rover67
    rover67 SILVER Star
    1,364
    26
    Sep 5, 2006
    Boulder, Co
    I've run 80 90 dino shlog from autozone with good results in everything.
    I did mobil 1 in everything for a while, and swapped it out for dino again. Then I went to MT-90 in the tranny to get it to shift nicer... now I am back to 80 90 cheapo stuff from autozone.
    synthetic is too pricey for me. the dino seems to do great...
  6. Spike Strip
    Spike Strip Why do I smell cheese? SILVER Star
    13,094
    3,451
    Nov 22, 2005
    The Beginning of the End
    Sta-lube 80w-90 in everything.
    Heavy Duty GL-5. Mil Spec. 9020 ... But I'll prolly move to MT-90 redline for H55 when broken in.
  7. Acadia
    Acadia
    437
    2
    Jul 10, 2007
    Olathe, Kansas
    80w-90 dino has worked well for me as well and I really don't see a need for me to run a syn. but the FSM has me second guessing my weight choice since in specifies 90w.
  8. Hank
    Hank SILVER Star
    1,426
    Albums:
    1
    9
    Feb 5, 2003
    Oshkosh, WI
    No problems with what you are running. There is better. I run Synthetic Viper 75w140 in my diffs. In the past I have run Amsoil with great success. Viper is much cheaper.
  9. inkpot
    inkpot SILVER Star
    13,194
    2,624
    Jan 30, 2003
    All over Arizona
    Howdy! I think that 80-90W is 90W when it needs to be.Just doesn't get quite as stiff in cold weather. John
  10. JLH911
    JLH911
    2,692
    Media:
    1
    Albums:
    1
    58
    Sep 2, 2007
    So. Cal
    Walmart Gear Oil for me...when I rebuilt the Diff, I'll go with Amsoil like I did with the Knuckle and Bearing Grease.
    Good luck.
  11. NocalFJ60
    NocalFJ60
    3,550
    Media:
    6
    Albums:
    1
    6
    Aug 2, 2004
    San Francisco Bay Area
    I buy a 5 gallon bucket of 80-90W gear oil at Autozone and change it often.
  12. Joe_E
    Joe_E
    3,552
    Media:
    39
    Albums:
    1
    152
    May 31, 2008
    the NJ word..
    Have always run 80W90 in everything and never had a problem. Just bought a five gallon pail of the Coastal brand but usually always ran Valvoline.
    Without a doubt buy a five gallon pail, it's a lot cheaper.
  13. inkpot
    inkpot SILVER Star
    13,194
    2,624
    Jan 30, 2003
    All over Arizona
    Howdy! I used to run the Valvoline 80/90W. I switched over to what we use at work on our big newspaper printing presses. I do get receipts to show I am paying for it. Schaeffer's industrial gear oils. It's about 2/3 times more expensive than Valvoline, but well worth it to me. Presses run cooler and quieter, and less wear on the gear teeth/bearings. I think it is 75-140W. Bucket's too faded to read. I run it in both diffs and all 3 gear boxes. John
  14. nuclearlemon
    nuclearlemon not an addict Moderator
    16,254
    Media:
    87
    Albums:
    4
    1,108
    Jan 30, 2003
    meh-ico, colorado
    i run 80w90 from the five gallon buckets bought from local oil supply store.
  15. Acadia
    Acadia
    437
    2
    Jul 10, 2007
    Olathe, Kansas
    are there any benefits/draw backs to running the 75-140w gear oil?
  16. Kernal
    Kernal
    6,118
    486
    Dec 10, 2007
    75W-90 Mobil 1 synthetic in diffs and transfer.
  17. inkpot
    inkpot SILVER Star
    13,194
    2,624
    Jan 30, 2003
    All over Arizona
    Howdy! Pretty much the same as motor oil. The 75 means it will perform/protect better (than straight 90) at colder temperatures, and the 140 will be better at extremely hi temps. The higher number MAY also help muffle gear noise. I do play in the desert a lot when it is over 110 degrees, so I like the idea of a little extra protection. John
  18. John Galt
    John Galt
    1,378
    62
    Jul 13, 2008
    Coldest N. America
    Realize that someone in Arizona will need a different grade than someone in Minnesota. It depends on the temperature extremes you'll be seeing.
  19. askeyey
    askeyey
    352
    1
    Nov 17, 2008
    Watertown, NY
    I just filled up with amsoil 80w-90 after installing the aussie in the rear. Perfect so far.
