G'day to all thought I had better introudce my self. Im reddog from down under I am the proud owner of a 76 fj45, bourght the truck as a stocker a few years ago only mod was LPG and some 31's on sunrasia rims drove it like that for a while and was pretty happy with the old girl, but me been me I couldnt resist the call of the angle grinder and welder so here I am the place where all good cruisers go to be cut up.
At the moment I have fitted a 3F motor to replace the origimal F and a 5 speed out of a 60 series the 60 also supplied 35 inch mud tyres, front and rear diffs the rear coming with an ARB air locker including compressor.
Now I did have 55 series front diff sprung over with the 75 series swivel hubs on the front with disk brakes and up the back a 75 series diff housing with 55 diff center sprung over.
I also had a 60 power steering box with 75 pitman arm.
Allthough this worked fine I couldnt resist putting th 60 diffs under. Why, they are a bit wider and a bit stronger and the angle grinder was getting a bit dusty.
Now I dont have any problems with spring overing the rear diff but the front has been a hole lot of fun. Since the springs had to be windend 35mm I decided to do a shackle reversal as well, I have reused the original hangers but have widend the front with a peice of 6mm thick U chanel, up the back I have tripple guseted the shackle hanger using 8mm plate. I am going to leave the springs turned around millitary wrap at front on fixed hanger because I like the approach angle.
Arfter all that here is my qiuck question. Has anyone repositiond there shackle hangers and later had them brake, or am I just been parinoid
