the bulb lighting up the tachometer is not lighting up. I finally got around to swapping the bulb but it didnt work. I moved that bulb to a different socket to confirm it is working properly, so I know the bulb is working. i actually got it to flicker for a second as i was moving it around but that was it.
Upon closer inspection, it appears the film around bulb socket is slightly ripped. i tried massaging it back around the socket but still wouldnt light up. it appears whatever metallic material (copper?) thats embedded into the film is now broken and doesnt have any continuity.
Has anyone ever ''repaired'' this area? is there anything i can put in there to get it to work? thought about putting the tiniest spec of aluminum foil in there but didnt want to risk frying the entire thing.
Looked into buying a used cluster off ebay to harvest the rear film but damn they are like 250 bucks...so I guess while Im in here...if anyone has a gauge cluster they want to sell cheap so I can swap over that rear film let me knowwwww.
