gas tank pressure bild up (1 Viewer)
sofaroffroad>U.S.A.
hi ,have a fj80,and after driving it ,open gas cap and a lot of gas pressure in there,any help in a fix or where to look at what is wrong.
Clutchee
I'm fun sized!
GOLD Star
Hotel M-F, home weekends!
Look at the charcoal canister being plugged, basically it acts as a filter & if it plugs then tremendous pressure builds in the tank & lines going back.
Look in the FSM & look under the charcoal canister checks, basically their is a test in which air passes through certain ways....... their is also a cleaning method.
Hope this helps, we fixed a buddies at Tellico using the manual-his was also building heat.
CJF
Ah.
That's a much better response than mine. :lol:
Question: Shouldn't a properly functioning cap still vent any excess pressure (even if the canister's clogged), or does it not work that way?
Curtis
Ah.
Curtis
I dont' believe they work that way. :cheers:
landtank
Groveland MA
on the later 80 the charcoal canister is vented through the bottom via a hose to inside the frame rail. The part that mounts to the frame rail can become rusted to a point where it will be plugged. A local guy had two gas tanks pressurize to the point of failure do to this.
sofaroffroad>U.S.A.
where do i find the charcoal canister on the fj80,and how do ya clean it,i don't have a book yet,also where to find 1
sofaroffroad>U.S.A.
on my truck,behind the battery is a big round canister for the air filter.any other place it can be and what does it look like
sofaroffroad>U.S.A.
so we are all here looking for a fix,so back to the charcoal canister,how do ya repair it/clean it or check the system, looking for help.standing by.
Gilbert, AZ
FWIW, I replaced my canister and still have the pressure problem. Must be the VSV or vacuum diaphram not pulling fumes through the canister.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
