I have a small of fuel. Can detect any leaks, just the smell. Send like it's coming from the drivers side. Amy ideas?
Hi Boss, is that on an 88? I called Napa and they didn't show a vapor canister for 1988. I'll look at my service manual and see if he was wrong. Thanks for the reply.If it’s in the cab, then I would take a look at your charcoal canister. Swapping mine out for the GM canister cures the fuel smell, infrequent vapor lock, and whoosh of the tank under pressure when I took the gas cap off.
AC Delco 215-153
It’s on my ‘84 FJ60. I just ordered the part off Amazon…the canister for our rigs is NLA. They are long gone, which is why I swapped to the GM canister.Hi Boss, is that on an 88? I called Napa and they didn't show a vapor canister for 1988. I'll look at my service manual and see if he was wrong. Thanks for the reply.
Oh, ok makes sense, thanksIt’s on my ‘84 FJ60. I just ordered the part off Amazon…the canister for our rigs is NLA. They are long gone, which is why I swapped to the GM canister.
The part number I gave you (AC Delco 215-153) is what I used.Oh, ok makes sense, thanks
Ok I'll see if that will work on mine.The part number I gave you (AC Delco 215-153) is what I used.
Call classic cruisers llc in Salina ColoradoOk I'll see if that will work on mine.
