gas odor from cap area on LX450
Discussion in '80-Series Tech' started by the magnetguy, Jul 13, 2005.
  1. the magnetguy
    the magnetguy
    186
    1
    May 17, 2005
    Calgary, Canada
    I've noticed on many occasions while washing my truck - a strong gas smell around fuel door on body of vehicle. Seems stronger when it's hot outside. I've checked underneath tank and all looks fine. Is it possible that the gas cap itself has a sealing problem? perhaps needing to be replaced. Anybody else notice this on their trucks?? - thanx - Tim
  2. silvercruiser
    silvercruiser
    308
    Mar 28, 2003
    Hermosa Beach, CA
    Hi had the same problem...bought a new gas cap with a good seal and the problem went away....
    cheers,
    David...
  3. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    21,987
    5,774
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    Time for a new cap, 77310-35080.
    D-
  4. e9999
    e9999 You want to do what...? Moderator
    16,594
    487
    Sep 21, 2003
    US
    so you're telling us your truck has gas?
  5. Romer
    Romer fatherofdaughterofromer Moderator
    10,709
    1,756
    Sep 14, 2003
    Centennial, Colorado
    I noticed just after I filled up if I parked on my driveway with a steep incline that a few drops would spill out (Not through the cap) and it would smell like gas. I figured out the incline and it being full let some gas get above the top of the filler nozle and it would drip ot some overflow tube thats there.
    Someone let me know if this makes sense. There is a circle just inside the cap area and it was dripping from inside the fender.
    Hasen't happened on any other ocassion
  6. Hants
    Hants
    439
    Feb 16, 2004
    Behind the bar
    Mine was leaking on a semi-full tank when driving on steep fire roads. I noticed the smell several times, but couldn't identify the source (exept to confirm it wasn't coming from the engine compartment :eek: ).
    I clued in when I saw the gas residue on the paint below the filler door :doh:
    I've since replaced the cap - thanks CDan - and haven't had any smells since. :)
    Curiously, it has passed PRK smog testing less than 6 weeks earlier :confused:
