In the past year or so I have tried to use a mechanical pump, an electrical and a used mechanical pump.
Right now Im running an electric fuel pump that puts out 4 to 5 psi.
The fuel line I am using comes from the threaded fitting on the side of my tank.
I am not using any return lines.
Im using a Holley 350cfm carb. (Whatever, I dont have linkages to run my rebilt FJ60 carb on my 40, so it sits on the shelf in a plastic bag.)
The electric pump is keyed to the ignition or the acc switch if there is one.
So, did I end up pumping gas into the engine through the carb while I was listenting to the radio while wrenching? Is the pump putting out too much pressure?
I just drained the oil due to a leak, probably caused by the oil which had a viscosity of water almost. I was going to drop the pan and add more RTV since I have a 4 piece oil pan gasket. Apparantly, it was due to the lack of viscous oil. This may have solved one mystery, but created a new one.
Im thinking that just installing a hidden switch to the pump will solve the issue. In the meantime Im looking to get a price on a new mechanical one.
