gas fumes coming from carburetor...
oes anyone else notice this? My garage can get real fumey after taking my 40 out for a ride. I've got a Holley carburetor in my 40 and it has a vent...the mechanic thinks the vent is the source of the fumes...any ideas fellas?
I would bet that the fumes are coming from a leak. Could be leaking internally into the manifold if you havn't noticed any leaks outside. Have you taken a good look around the whole thing? Might try holding a lighter around the suspected areas to see if you can locate the leak. Remember to wear safety gear though. ;)
Just kidding, don't do that!:hillbilly:
holly carb is like a toilet bowl for a carb...if flushes alot of gas down the drain...and when its done flushing some gas remains at the bottom of the intake manifold...you are smelling that gas.if you have a K&N filter you will smell it worse...an open paper air cleaner ...will smell not as bad...a stock setup the smell has to travel thru the aircleaner ductwork and then thru the very big aircleaner to get out. :)
mine has a weber...a smaller toilet bowl :) with a K&N filter...it smells
