Builds FZJ80 The Devils Build (3 Viewers)
Pakistan/UAE
As A Toyota Lover Had Done A 70 Series Project Recently & Jumped to 80 Series ...
A Bone Stock FZj80 In My Garage Was Welcomed Recently ...
Em kinda Person Who Like To BUILD Machines With Heart & Keep Them Like My Home Members ...
Enough Writing :p Lets Introduce U To My RIG
" The Devils "
Make : Toyota Land Cruiser 80 Series (FZJ80)
Year : 1997
Milage : 117000 km
Body Color : Golden/Sliver
Body Shape : Squared 5 Door
Suspension : Soft/hard
Engine : 1FZ-FE (4500cc)
Fuel Type : Petrol
Transmission : Auto 4x4 (LSD)
Wheelbase : Long
Interior : Brown
Options : Sunroof, Power Windows, Power Lock etc
Token : 2017 Paid
Condition : All Stock So Far With No Accidents Or Touch-ups
Jeep Club : ZOR (Zalmi Offroad Rally Club), Pakistan
25/07/2016 - Updated After Mods
18/07/2016 - Stock Condition
Hope I Will Build It ... Stay Tuned .. I Will be Back With The List ..
Check List For Mods Added :
Exterior :
Offroad Wide Fender Flares Set
Bug Shield Back
DEPO 6 Piece Set Front Head Lights Crystal
Full Body Wrap 3M Satin Yellow Bitter
Interior :
All Original
Engine & Gear :
NGK IRIDIUM (IX) Spark Plug - 6 Pieces
Aeromotive 11140 Fuel Pump 340lph Stealth Pump
Magnecor 65234 8.5mm KV85 CN Series Ignition Cable
Nitro 4.88 Ratio, Nitro Front & Rear Gear Kit
The "TRU FLOW" Toyota Timing Chain Kit (as after 100,000km required)
50mm 13 Row AN-10/AN10 Double - Deck Oil Cooler Hose Filter Relocation Kit
Exhaust & Headers :
Borla Cat Back Exhaust System Purchased.
(permanent plan)
Genie Headers Long Tube Set
MangaFlow 23622 Catalytic Converter Front
Kool It Heat Warped On Headers
Kool It Heat & Rust Proofing On Headers
Heat, Rust & Sound Control System :
DYNAMAT 72 Sq ft Heat & Sound Proofing All Floor Inside
Rubber Coating Water & Rust Proofing Under Chassis
Suspension, Break System & Axles :
4" Lift Kit Stage-2 Suspension Package " PEDDERS "
30mm Front & Rear Polyurethane Coil Springs Spacers
The 4" DropBox Kit
Nitro Chromoly Birfield & Axel Kits
30 Spl, Nitro Chrmoly Rear Axel Kit (Full Float, Pair)
Heavy Duty Axles & Bearings Kit by NITRO
Draglink Chrome Moly 4140 Steering Arm 38mm
Solid Chrome Moly 4140 Tierod Rock Rod 38mm
Wheels & Breaking System:
Mickey Thompson Baja Claw Radial 35x12.50R15
Mickey Thompson Rims 15" Light Weight 10" Wide
G2 1.5" Wheel Spacer Black Coated Aluminium
The Hawak Performance LTS Brake Pads Front Set
The Hawak Performance LTS Brake Pads Rear Set
Bumpers & Winch :
Front Off-Road Bumper (Custom Desgin)
Rear Off-Road Bumper (Custom Desgin)
Winch Warn Zeon 10 Premium Series
Performance Parts :
K&N Gold Oil Filters
K&N Pro Oil Filters
K&N Air Filter
ARB Safari Snorkel V-Specs SS81HF
HPS RED Reinforced Silicone Radiator + Pesky Heater Hose Kit
Lighting System:
Rigid Industries Radiance 50" Red Back Light LED Bar - 25002
Rigid Industries Radiance 30" Red Back Light LED Bar - 23002
Warn Bumper Spot Lights
Entertainment System :
Head Unit
DVD/GPS Unit
Front Stage
Speakers
Focal FP 2.150 LE Amplifier (2 Channel Dynamic Capacity 1 x 400W rms available into 4 Ohms)
Rear Stage
Speakers
Focal Solid 4 (400w 4 channel amplifier, With 4 x 75W RMS power into 4 Ohms and 4 x 100W RMS into 2 Ohms)
Woofer :
Kicker S15L7 Solo Baric
Kicker ZXS 1000.1 Amp
Monster 202LN High Performance RCA 5m Lead 2 Channel.
Kicker PKD1 3000watts 0 Gauge 6.1m +ve & 1m Ground / Kicker Fuse Box Kit
Kicker Woofer Safety Grill
Off-road Tool Kits & Accessories
Looking forward to it. Welcome to the 80 series board.
Shopping Time ...
Exterior :
Offroad Wide Fender Flares Set (purchased Pending Installation)
Bug Shield Front & Back (purchased Pending Installation)
DEPO 6 Piece Set Front Head Lights Crystal (purchased Online)
Engine & Gear :
NGK IRIDIUM (IX) Spark Plug - 6 Pieces (purchased Online)
Aeromotive 11140 Fuel Pump 340lph Stealth Pump (purchased Online)
Magnecor 65234 8.5mm KV85 CN Series Ignition Cable (purchased Online)
Nitro 4.88 Ratio, Nitro Front & Rear Gear Kit (purchased Online)
The "TRU FLOW" Toyota Timing Chain Kit (as after 100,000km required) (purchased Online)
50mm 13 Row AN-10/AN10 Double - Deck Oil Cooler Hose Filter Relocation Kit (purchased Online)
Exhaust & Headers :
American OffRoad "Mid Exhaust" & Ganador Muffler Single Tip (Have In Stock Will Install in a Day or So) (Installed)
Borla Cat Back Exhaust System Purchased.(purchased Online)
Genie Headers Long Tube Set (purchased Online)
MangaFlow 23622 Catalytic Converter Front (purchased Online)
Kool It Heat Warped On Headers (purchased Online)
Kool It Heat & Rust Proofing On Headers (purchased Online)
DYNAMAT 72 Sq ft Heat & Sound Proofing Inside
(Australian Brand For Suspension Solution) (purchased)
30mm Front & Rear Polyurethane Coil Springs Spacers (purchased Online)
The 4" DropBox Kit (purchased Online)
Nitro Chromoly Birfield & Axel Kits (purchased Online)
30 Spl, Nitro Chrmoly Rear Axel Kit (Full Float, Pair) (purchased Online)
Heavy Duty Axles & Bearings Kit by NITRO (purchased Online)
Draglink Chrome Moly 4140 Steering Arm 38mm (purchased Online)
Solid Chrome Moly 4140 Tierod Rock Rod 38mm (purchased Online)
Mickey Thompson Baja Claw Radial 35x12.50R15 (purchased)
Mickey Thompson Rims 15" Light Weight 10" Wide (purchased)
G2 1.5" Wheel Spacer Black Coated Aluminium (purchased Online)
The Hawak Performance LTS Brake Pads Front Set (purchased Online)
The Hawak Performance LTS Brake Pads Rear Set (purchased Online)
Bumpers & Winch :
Performance Parts :
K&N Gold Oil Filters (purchased Online)
K&N Pro Oil Filters (purchased Online)
K&N Air Filter (purchased Online)
ARB Safari Snorkel V-Specs SS81HF (purchased Online)
HPS RED Reinforced Silicone Radiator + Pesky Heater Hose Kit (purchased Online)
Lighting System:
Rigid Industries Radiance 50" Red Back Light LED Bar - 25002 (purchased Online)
Rigid Industries Radiance 30" Red Back Light LED Bar - 23002 (purchased Online)
Head Unit
DVD/GPS Unit
Front Stage
Speakers
Focal FP 2.150 LE Amplifier (2 Channel Dynamic Capacity 1 x 400W rms available into 4 Ohms) (purchased Online)
Rear Stage
Speakers
Focal Solid 4 (400w 4 channel amplifier, With 4 x 75W RMS power into 4 Ohms and 4 x 100W RMS into 2 Ohms) (purchased Online)
Woofer :
Kicker S15L7 Solo Baric (purchased Online)
Kicker ZXS 1000.1 Amp (purchased Online)
Monster 202LN High Performance RCA 5m Lead 2 Channel. (purchased Online)
Kicker PKD1 3000watts 0 Gauge 6.1m +ve & 1m Ground / Kicker Fuse Box Kit (purchased Online)
Kicker Woofer Safety Grill (purchased Online)
Off-road Tool Kits & Accessories ..(Purchasing In process)
I Think enough Shopping for today ... Seems I Got Crazy ... Spend today alot of $$$$$$$ ...
just now waiting for the shipment ... Let The Fun begin ...
Aeromotive 11140 Fuel Pump 340lph Stealth Pump (purchased & Received)
Wait, wait, wait, wait. Steerings on the wrong side!
ha ha ha YES ..
its a RHD as in my home county Pakistan .. All Vehicles are RHD.
i live in UAE (Job) ... I Have Vehicles here too those are RHD.
Genie Headers Long Tube Set Received ...
Super Fast Shipping Paid $$ DHL
Can't wait to see what these headers look like! I am glad to have someone here from the UAE as I think they have a very unique Land Cruiser market and I am excited to see some of those types of builds as they are very outside the box from the same old same old we see here on Ih8mud.
What kind of wheels are those? I know in your list it says Mickey Thompson rims, but those are not any MT's that I am familiar with. :) They don't look like they are a true 2 piece, or was the separation just filled when they painted them?
Wheels Received ...
Check Out The Naughty Smile By My Younger Brother ...
Heat & Rust Proofing .... Left For 24 Hours
Finally Ready ... Next Process Heat Wrap ..
Yes They Are Not The MCKY Wheels Are Those Also Revived ... I Will Share Pic today ..
These Are The 15" BBS Style 10" Wide .. I Liked Them So Bought It ...
Thank u For ur Kind Words ...
Well My Rig Is In Pakistan & I Am Importing All The Products Here To UAE First .. As I Do My Job Here ...
So Once I Get All Parts (I already Paid For Fast Shipping) Then Will Send It To Home Country To Install It ..
Yes Here We have Crazy Landcruiser's In UAE ..
Unpacking For Headers is done check it out above :)
Heat Wrapping Process Final Stage ..
It Took a lot Time ...
Wrapped & Sprayed Again ... Seems em Cray eheehe
& Finally Ready ... All Done
Got Hands on the Dynamat 72Sqf .. 9 Sheets + 1 Free total 10 ..
well use this on floor inside ... Specially near to Gear Console & Front Cabin
Received The HAWK LTS (Light Truck SUV) Brake Pads Set Front & Rear ..
Received The New Intake Pipe ... Old Was A Bit Broken ..
