Fzj80 fuel consumption
I’ve done:
Spark plugs
Distributor
Spark plug cables
Vacuum hoses
Radiator
Thermostst
Water hoses
Alternator
Distributor
Need to fix:
EGR
O2 sensors
When the truck is in idle speed, I can feel some smell, “old car smell”, but can’t tell if it is from a rich mixture or from clogged exhaust system
Did you see the recommendation of pulling / re installing the EFI fuse and driving it on a open road trip to relearn the EFI computer? I'm sure disconnecting the battery for 20 min will work. I'm going to try this, I'm having the same issue as you mention. In the past I disconnected my battery to do some work and then only drove around town for months (stop and go) EFI didn't properly re learn. I'm going to test it out soon. I'm currently averaging 10.2 to 11 mpgs
Will try it in an upcoming trip I have in a few weeks. almost 1.000 km (625 miles).
Where exactly is the EFI Fuse, on the fuse box on the left side of the steering column (inside the cabin) or in the Fuse/Relay box on the engine compartment? Sorry for the question, I done have my owners manual.
I think 🤔 it’s in the engine bay and it’s labeled EFI but I could be wrong, I’m. Just going to disconnect my battery so I can clear my head unit Bluetooth settings
OEM ride height
OEM Michelin LTX 275/70/16 tires at 35 PSI cold (the tire designed specifically for this application).
Throw everything that is not absolutely necessary overboard
Under 65 MPH top speed
Real gasoline (no ethanol)
These things were designed in the 1980s when the speed limit was 55 MPH. 55-60 is the economy sweet spot.
U r right!
Found this
OEM ride height
Absolutely agree with you about throwing overboard unnecessary stuff and speed. Top speed I do on my 80 is about 60-65.
I guess I didn't state the weight of my truck in my mileage thread for reference.
I'm always at 6200-6300 without me in it. That's somewhere around 600-800 LB of tools, parts, and gear I need for job sites.
