Wanted FZJ80 axles
Fremont CA
FZJ80 axles wanted. Lockers would be nice but as long as they are complete front and rear axles with all suspension linkages/brake lines/brake components then I will be interested.
located in NorCal
Did you post on FB also?
I have a rear FF from a 97. Brakes are complete. I think the panhard is still attached and the brake lines are intact. Located in Gustine, near Los Banos.
I have a front for sure and I could probably scrape up a rear as well. The problem is I'm in Idaho. And I have all the arms and hardware. I even have an extra frame should mounts need to be cut off of it.
