NorCalFJ100
Happy Super Bowl Sunday to all you watching! I am sure this thread will get some traction later tonight or tomorrow. Haha.
Okay, so some backstory....I bought the truck with a bad motor and the hard line to the AC Drier broken. So have no idea condition of AC previously. When I removed the motor I removed all AC and blocked any hard line open holes. The AC drier however was left to the elements with a hole from where the pipe broke.
When I removed the AC Compressor I wasn't very educated at the time with AC systems and a bunch of oil came out of it...no idea how much. I proceeded to try and remove the balance of what was in there.
Fast forward to today. New motor is in. All is well. Didn't touch the AC at first...things are starting to heat up in SoCal! Need to get on the AC.
1.) Bought a new drier line from the dealer. Replaced all the o-rings from the hardlines I removed. Bolted it all back together.
2.) I added the proper oil to the compressor. Unsure of how much is in there (although I couldn't really get more to come out) I added about half the bottle. I think I also made a mistake here and should have added more.
3.) Bought a vacuum pump from Amazon. Proceeded to pull a vacuum and it got to about 28 HCG. I held it there for about an hour. All was stable.
4.) Ran the vacuum for about another hour to attempt to pull any moisture etc from the system.
5.) This is where I think I really messed up...I hooked up the first can of 134a and opened both valves with the truck running. First can emptied pretty quick. The second can I had to mess with and shake it...I thought I got it all out, but it was probably 90% of it. The third can I really had to fight with and only got about half out. Can froze up several times, etc.
Now I have no cold air. I have no idea the condition of the compressor, expansion valve and hindsight I should of at replaced the drier unit when I ordered that replacement hard line.
6.) I closed up the garage last night. Woke up this morning and connected the high and low side. Opened both valves and the reported the same PSI on both sides. To be expected with the AC off.
7.) I turned the truck on and AC on...The high and low side raised PSI slightly to 75 and they were the same on both sides. Picture below, not a great one. I realize part of the high side gauge was covered, but it was the same.
Today is about 72 outside. 41% Humidity.
Question: Should I just plan to evacuate the system, replace the compressor, expansion valve and drier? What about condenser? I just want this thing to be dialed in and problem free. I spent so much time on the rest of the truck. She's a lifer at this point.
THANKS MUD!!!!!!!!!!!
I was also thinking about replacing this hard line if I have to take this all apart again anyway...Thoughts?
