@Malleus Thanks !!! do you have any way to send a few pic's of what you are talking about ? I think i'm picking up on it but a picture or two would help a lot !! Do you think I will need to remove the headliner to do this repair ?
Sorry, I don't have any from my work, and it's raining out now, so I can't get any until tomorrow. The lower body screws are easy to find; run your hand down the rear edge of the front fender, around the lower bend. The rearmost screw, with a large fender washer on it, is at that point. The front screw is about an 1.5" forward of that.
Yes, you have to drop the headliner, but not the trim on the A pillar. The holes in the pillar that the hose is routed through are not in a straight line. I tried for over an hour to push the tubing up from the floor and it kept binding. It took me 5 minutes pulling it down from the roof to get it in place.
You'll want to use a plug in the lower end of the tubing, with a string in it, to use as a pulling device. Attach the lower end of the string to the upper end of the front drain tube you're replacing and use the tubing to pull the string down through the body panels. Then attach the upper end of the string/plug to the lower end of the rear tubing you're reinstalling in the front tubing location, and pull that tubing down. Same process for both sides.
I soaked my replacement tubes in warm soapy water and ran a brush through them before I installed them. This is the only way to clean a sunroof drain tube, and it's impractical to do it while the tubing is in the body.
Be aware before you begin, this is not a 5 minute fix. I probably spent 3 hours doing this, not counting the time I lost fiddling with the tubing before I figured out the easy way to replace it. If you have an early 80 without the headliner tray, it'll be that much more difficult.
@jsloden's idea is much simpler, but you risk kinking the tubing as it comes out of the pocket and behind the plastic kickpanel. That's the reason I chose my workaround instead of his.
