This thread is not to be about issues of delivery. Only documenting replacement parts fixes for issues and documenting the different versions of his adapter system over the years.
Lets accumulate part numbers and applications of parts used for reference. If there are question marks after details it indicates that the info needs to be verified, but is an educated guess going on memory not a verified result (will update).
Accessory adaptor plate:
Quick Mount Cummins AC
-1991.5-2005 Dodge diesel Sanden AC compressors
-1989+ Dodge diesel Denso alternators
-Ford 3 bolt FS10 AC compressors gas and diesel
-Ford 3 bolt pad mount alternators with 8 groove pulleys (diesel)
-Uses 89-2002 Dodge diesel belt tensioner
Belt - Alternator pulley Diameters been found to very 2.5" vs 2.75" so belt length may very as well.
K080797 is the original that fits with the larger 2.75" Pulley
Belts that DO NOT WORK (will delete if the correct one is found) K080791 is to short with 2.5" Pulley and K080795 is to long with 2.5" Pulley. There is a K080704??? that might fit would likely need a K080792/3 for the smaller pulley
Adapter and starter:
- Early version: custom adapter plate cummins B-series to Toyota 1FZ pattern for transmission:
- Starter - ford 6.4 Diesel 2008-2010???
- Tach pickup - Dakota digital have found PN: MSP6724 to work as replacement (3/4" - 16UNF Thread magnetic speed sensor)
- Remove the bottom of the adapter by cutting off the lower section to gain access to engine oil pan bolts, also makes it easier to access to torque converter bolts (pictures to be added in posts following.
- Torque converter: stock toyota with stall lowered (stock one unmodified does work just need to keep the engine RPM higher to put the power to the ground)
- Flex plate custom for Cummins crank to Toyota Converter
Later version: using dodge adapter and starter with custom bell housing
what year adapter 89-93 or 94-98???
- Stock toyota converter with modified base to adapter to Dodge footprint and flex plate
Keywords for search: Diesel adapters, Allmaras machine, Dustin Allmaras, Duiser offroad
